Tiger86_92132
Apr 19, 2011Nimbostratus
A simple load balancing network
I'm using BIG-IP 1600 with LC module. I need to config a simple load balancing network (just need outbound load balance), here's my network:
- I have 2 VLAN external for 2 internet lines, with 2 modems connect PPPOE to the Internet (use NAT on modems) (192.168.101.0/24 and 192.168.102.0/24)
- and 1 VLAN internal for clients (10.8.23.0/24)
I followed the configuration guide:
- create VLANs
- config self IPs for all VLAN
- define 2 Links for internet lines
- create Pool named default_gateway_pool that include 2 LAN IPs of the modems
- define a wildcard virtual server with default_gateway_pool
- create default route: using Pool default_gateway_pool
From F5, I can ping clients, LAN IPs of routers and ping to the Internet but from client, I can ping only the self IP of internal VLAN. I use self IP of internal VLAN for gateway for clients, is it rights ?
Could anyone tell me what step I missed ?
Many thanks
