Sort By
- Greasy_PretzelRet. Employee
you can create parameter but there is no option to save values. In case you need these values to be recorded so an action can be taken on them, you may need iRule (depending on what you are doing, and the task is complex, I recommend contacting f5 professional services).
- Gareth_AllenAltostratus
Thanks for your response.
I don't need to record the response, only validate its content. I'd like to create a parameter named "verify" as a user input value, but due to the delimiter being a "?" ASM doesn't pick it up as a parameter. If it was http://url/verify=1.8000 it would make life much easier.
