THE_BLUE's avatar
THE_BLUE
Oct 31, 2023
BIG-IP Configuration utility unauthenticated remote code execution vulnerability CVE-2023-46747
F5 annaounce new CVE and there is ENG hotfix only. But there is mitigation as mentioned in below link :
https://my.f5.com/manage/s/article/K000137353
where step 1 was:
1-Copy the script below (or download it) and save it to the affected BIG-IP system. so where i have to save? in which partion?
and in step 3
3-With a text editor of your choice such as vi, create the md5 file, mitigation.txt.md5 in the same directory as the script using the following content: how to do this?
and the last point, does this script/mitigation will have an affect on WAF or it will make it offilne ?
  • For step 1: In the example the /root directory is used for the script. So you can save the script in the /root directory.
    For step 3: you can also use the following command to create the mitigation.txt.md5 file:
    echo 'baeb2859223dba55737f445f1e86a56a  mitigation.txt' > /root/mitigation.txt.md5
    Execution of the script doesn't affect the WAF or make the BIG-IP offline. The article says: Impact of procedure: Performing the following procedure has no impact on data plane traffic.
  • The script has no impact on traffic being routed via LTM, because the procedure has no impact on data plane traffic.
    The script will change two files:
    • /config/httpd/conf.d/proxy_ajp.conf
    • /etc/tomcat/server.xml
    They will be backed up to:
    • /config/httpd/conf.d/proxy_ajp.conf.f5orig
    • /etc/tomcat/server.xml.f5orig
    So you could perform a diff on them, to see if the files have being changed.
    If you want to test if your BIG-IP isn't vulnerable anymore to CVE-2023-46747, you can use nuclei to test against your BIG-IP. If your system is still vulnerable, a new user has been added to your BIG-IP.
    See:
    Here an example of testing it myself. The below picture shows performing the test on my unpatched BIG-IP. The result of nuclei seems to say it wasn't sucessful, but it was partially.
    The picture below shows that it has added a user 'O5ZFM'. However, nuclei wasn't able to login with the user it added. So the template may need a bit more work.
    After applying the patch from K000137353, nuclei was unable to add users. So this confirms that the patch did it's job.
  • RE:  K000137353: BIG-IP Configuration utility unauthenticated remote code execution vulnerability CVE-2023-46747
    How do you know the script has an effect?
    Also does the script impact ltms where traffic routes through the ltm and not to a virtual server.
    • Niels_van_Sluis's avatar
      Niels_van_Sluis
      Icon for MVP rankMVP
      See:
