mthornton42_217
Oct 01, 2015Nimbostratus
Solved
Blade Migration Script Location
I'm guessing that the chassisConfigUpgrade.pm script will come on the new blades, I just want to confirm. If it doesn't, where is it available for download? I looked through the downloads section and was unable to find it.
We just got done doing this. Yes, the script comes loaded on the blades. Just as a helping note, make sure you have all the image ISOs on your host and vCMP guests if using vCMP for the installed volumes you have. If not, it will just sit there waiting for the ISOs to be available.
