Block uri iRule review....Pls
Hello I just have a simple requirement ie to allow only certain uri's. I just want to check to see if the below iRule will do the trick and not cause any problems...
if { [class match [HTTP::uri] ne "allowed_uris"] }
drop
And I create a data group called "allow_uri's" with /sales, /reports,/data
Will the above irule block www.abc.com/sales/1quarter/check? since I did not specify the second part of uri...should I also add "/sales/1quarter/check?" to the data group or just add "/sales/*"
What are pro's and con's using drop vs reject.I know reject sends a notification back saying invalid request.
Thank you.
