Am not sure this is possible in the GUI. Maybe you can do something with a external monitor that combines HTTP1_monitor and HTTP2_monitor?
https://devcentral.f5.com/wiki/advdesignconfig.externalmonitor.ashx
Regards, Martijn.
- Leonardo_SouzaCirrocumulus
Via GUI you can add multiple monitors to the pool, working like an "and". You can then define how many of those monitors need to be up at minimum, so the system marks the pool member up.
Looking your requirements, if an HTTP monitor is up, implies that you can talk with the server, so Gateway_ICMP_Monitor is redundant here. Similar thing in relation to TCP_Monitor, HTTP work on top of TCP, so this monitor is also redundant.
Assuming the HTTP monitors are different, you can add both to the pools. If you need both up, select availability for all. If you need just one of them up, select availability 1.
- MR_FreddyNimbostratus
@Martin, ok can you guide me to do that ?
More information on external monitors can be found at:
You need to know some scripting to write you own external monitor.
Maybe you discover an external monitor is not the solution for your problem, but you can have a look at it.
Regards,
Martijn.
