riyad_fami_1308's avatar
riyad_fami_1308
Oct 30, 2016
custom SSL cipher suite
Hi, We have F5 LTM software version 10.2.3 and we are trying to setup Vmware Identity Manager load balanced through the LTM. The VIP uses server ssl profile serverssl-insecure-compatible. Apparently the servers are negotiating to use a cipher which is not supported by the default cipher suite. As per the vendor we need to have an SSL profile with cipher suite similar to LTM version 11.5.1. I have read about COMPAT ssl profile but not sure if this is exactly what im looking for. Can you advice me is we can configure SSL profile with the custom ciphers and the steps how to do it.
Thank you.
  • As per SOL7815, 10.2.x code version's default cipher suite is:
    !SSLv2:ALL:!DH:!ADH:!EDH:!MD5:!EXPORT:!DES:@SPEED
    As per SOL13171 default ciphers for 11.5.x is
    !SSLv2:!EXPORT:RSA+AES:RSA+3DES:RSA+RC4:ECDHE+AES:ECDHE+3DES:ECDHE+RC4:!MD5:!SSLv3
    Normally, the recent code versions tend to support the newer cipher suites like the ECDHE. I am not sure if that can be made to work in 10.x code version.
    I would recommend the following:
    1. 10.x code version will be End of Support December 31, 2016. If this is a new set up, you may want to consider upgrading your code before setting it up as you will be looking at a code migration quite soon.
    2. If you don't want to upgrade code, provide the cipher suite available in 10.2.x code version and make sure that it is supported. Even if all the ciphers suites are not supported, some will be supported and that should suffice for your setup to work.
