krazzy522
Feb 02, 2023Altocumulus
Decision box design using js
dear all
I am trying to update decision box design using JS file, I have done it in login page by following this link login design and I am thing to update same in other pages
define(["require", "exports", "tslib", "module", "apmui/page/decisionBox/View"], function (require, exports, tslib_1, module, View_1) {
"use strict";
Object.defineProperty(exports, "__esModule", { value: true });
requirejs.config({
map: {
'apmui/master/View': {
'apmui/page/decisionBox/View': module.id,
/* Replacement View component */
var DecisionBoxView = /** @class */ (function (_super) {
tslib_1.__extends(DecisionBoxView, _super);
function DecisionBoxView() {
return _super !== null && _super.apply(this, arguments) || this;
DecisionBoxView.prototype.componentDidMount = function () {
_super.prototype.componentDidMount.call(this);
requirejs(['https://d3js.org/d3.v6.min.js'], function (d3) {
var itea = d3.select("main").html("<div id='itea'><img src='https://mc.com.sa/file/Image/itea.png'></div>" + d3.select("main").html());
return DecisionBoxView;
}(View_1.default));
exports.default = DecisionBoxView;
Take a look at Advanced Customizations here: https://community.f5.com/t5/technical-articles/apm-advanced-customization-examples-with-modern-template-v15-1/ta-p/288979
You'll need to modify the CSS in order to add an image to the decision box.
I have inserted div in JS file like below and added CSS to the div
thank you for your time and support
var divLogo = document.createElement("div");
divLogo.id = "logo";
document.body.appendChild(divLogo);
var img = document.createElement("img");
img.setAttribute("src", "logo.png");
divLogo.appendChild(img);
