Sort By
- pete_71470Cirrostratus
In v11, you can use the show command in tmsh to find the records, ensuring they're the correct ones, then change 'show' to 'delete':
show ltm persistence persist-records node-addr 1.2.3.4
Then:
delete ltm persistence persist-records node-addr 1.2.3.4
If you delete members from the pool, surviving members will be chosen for load balancing even if there is persistence to the DOWN members.
- Wasfi_182818Nimbostratus
Can the deleting of persistence records be done at the pool member granularity too?
Kindly Wasfi
Hi Wasfi,
show ltm persistence persist-records pool
delete ltm persistence persist-records pool node-addr 1.2.3.4
Cheers,
Kees
