Sort By
- Jad_Tabbara__J1
Hello Paul,
You can do it by different manner. One of them consist of :
1) From VS_A : Add the "X-Forwarded-For" header using either the HTTP profile or by adding an irule that insert this header.
when HTTP_REQUEST { HTTP::header insert X-Forwarded-For [IP::remote_addr] }
Reference : https://support.f5.com/csp/article/K4816
2) From VS_B : You will need to add the following irule, that will use "Universal persistance" on XFF header
when HTTP_REQUEST { set clientip "" if { [HTTP::header exists "X-Forwarded-For"] } { set clientip [HTTP::header "X-Forwarded-For"] } else { set clientip [IP::client_addr] } persist uie $clientip } when HTTP_RESPONSE { persist add uie $clientip }
Reference : https://devcentral.f5.com/questions/universal-persistence-with-x-forwarder-47038
Please give us a feedback.
Hope it helps
Regards
- Robin1
Hi Abhilash, is your issue resolved? I am on the same boat, tried all possible scenarios still not working.
