Terrence
Jun 15, 2012Exchange OWA Enhanced login timeout
So this is my second post on this topic, and I am starting another post, because the earilier post has much information that was no longer relavent.
We are currently in the deployment stages of a new Exchange 2010 sp2 environment. We have a redundant pair of LTMs internally fronting rpc,autodiscover and ews. This is all functioning as expected.
We Then have an Edge gateway in our dmz which is fronting OWA and activesync.
All of our F5 gear is running 11.2 HF2, and we are using the f5.microsoft_exchange_2010_cas.2012_04_06 template and corresponding design guide.
A few weeks back our Administrators pointed out that OWA via the Edge gateway would never timeout, after doing some testing, this proved to be true.
A little bit of googling turned up this kb from Microsoft http://support.microsoft.com/kb/2478286
It seems that the Exchange template doesn't account for this. In my original post regarding this article, I thought I had found a solution as listed below
when ACCESS_ACL_ALLOWED {
set mrhsession [HTTP::cookie value "LastMRH_Session"]
if { [table lookup $mrhsession] == "EXCHANGE_LOGOUT" } {
set user_logon [ACCESS::session data get "session.logon.last.username"]
set sessionid [ACCESS::session data get "session.user.sessionid"]
log local0.warn "OWA Exchange Initiated timeout - Session: $sessionid, User: $user_logon"
ACCESS::session remove
table delete $mrhsession
when HTTP_RESPONSE {
if { [HTTP::status] == 440 } {
log local0.warn "OWA Exchange Initiated Timeout"
if { $mrhsession != ""} {
table set $mrhsession "EXCHANGE_LOGOUT"
log local0.warn "OWA Exchange Initiated Timeout - MRHSession: $mrhsession"
unset mrhsession
So for a week I was convinced that this rule resolved the issues. To Which I found that i was incorrect, and upon further investigation discovered that OWA uses the 440 response code quite liberally. Some users would log in via APM and get ejected almost instantly. So I modified the rule.
set apm_mrhsession [HTTP::cookie value "MRHSession"]
if { [table lookup $apm_mrhsession] == "EXCHANGE_LOGOUT" } {
log local0.warn "OWA Exchange Initiated timeout - Session: $sessionid, User: $user_logon, MRHSession: $apm_mrhsession"
table delete $apm_mrhsession
unset user_logon
unset sessionid
unset apm_mrhsession
set isset 0
set request_uri [HTTP::uri]
if { [HTTP::uri] contains "UA=0" } {
set mrhsession [HTTP::cookie value "MRHSession"]
set isset 1
if { $isset == 1 } {
if { $mrhsession != "" && [HTTP::status] == 440 } {
log local0.warn "OWA Exchange Initiated Timeout $request_uri- MRHSession: $mrhsession"
unset mrhsession
unset request_uri
return
unset isset
unset mrhsession
log local0.warn "OWA Exchange Liberal Use of STATUS 440: $request_uri"
unset request_uri
I am really surprised that noone else is seeing this issue? How are other people resolving this issue? Is there perhaps an easier way that I am not aware of? Did I miss something in the deployment guide? Depending on the response I might open a ticket with F5 with the issue.
