Vulcana's avatar
Vulcana
Mar 08, 2024
Solved
F5 APM with OIDC Web Duo Prompt
DUO is retiring the iFrame support which has been working well for us.  I am trying to implement the replacement found at https://duo.com/docs/f5bigip-web and APM Configuration to Support Duo MFA using iRule | DevCentral
This is our first JSON / OAuth implementation and I think I missed something in the setup
The DUO subroutine is implemented after the initial AD Authentication and Query
When I attempt to log on with the VPN client I get past the AD Authenticiaton but when the DUO challenge is to appear it fails and rolls back to the AD Authentication prompt screen.
The error I pulled out of the access report is
/Common/duosubroutine_act_oauth_client_ag: OAuth Client: authorization_code is required to get access_token for server '/Common/duo_server'
I am attempting to configure this as a per session policy.  To my limited understanding I believe the secret is not being properly passed.
Could anyone provide steps for troubleshooting this?
Thank You
  • For those who may run into this in the future sometimes it can be difficult to distinguish a _ from a - in the article.  Should you run into this check for
    • client_id parameter with type client-id
    • response_type parameter with type response-type
    • grant_type parameter with type grant-type
    • redirect_uri parameter with type redirect-uri
