- Naveen_ShanmugaNimbostratus
VMnet1 Subnet adapter i have mentioned 10.1.0.1 , Now i can able to ping the IP , but i couln't browser the 10.1.0.145. Kindly suggest me further .
I just tried the following on my PC with VirtualBox.
Enable the VirtualBox Host-Only Network Adapter.
Give the Adapter the IP Address of 10.1.0.1 with a Subnet Mask of 255.255.255.0
On the BIG-IP in the config screen add a default route with an IP Address of 10.1.0.1
You should now be able to ping and browse the 10.1.0.145 address.
- Xtekni_240126Nimbostratus
Thanks that seems to have done the trick.
Are you able to ping the 10.1.0.145 address from your PC?
I used VMware player but I had a similar issue. In VirtualBox make sure that VMnet1 Subnet settings is set to the 10.1.0.0 Subnet.
On my PC the VMnet1 Adapter has a static ip of 10.1.0.1 subnet mask 255.255.255.0
Well I was wondering if the virtual adaptor should have an ip on it when viewing it rom the network settings on the windows 10 machine. I did try putting 10.1.0.1 at one point as a test to see if that helped. But it did not and I have not been able to ping the 10.1.0.145 address at any point on either PC that the lab is installed on. There must be something stupid I have missed. It cannot be this difficult to setup a LAB on a VM.
