mwi
Nov 15, 2023Altocumulus
F5 LTM manual resume problem
we have configured a pool with two nodes, one primary and one secondary, every node has its own monitor.
The primary node monitor has set the option "manual resume" so if this node isnt avalible, the traffic goes to secondary, but doesnt switch automaticly back.
It works under normal circumstances fine, but yesterday we had some network issues so that the active loadbalancer lost the connection to the primary node, the passive loadbalancer had no problems.
We had to take down the active Loadbalancer and now the problem was that the before passive loadbalancer routed traffic to the primary node again.
Is there any solution to sync the node status automaticly?
Best regards.
