f5mkuDefault
May 17, 2021Cirrus
F5 LTM traffic flow
Hi experts,
Just wanted to ask. usually I used show sys connection cs-server-addr or cs-client-addr to see if client is able to reach its destination server.
show sys connection output:
client\source ip > VIP > snat IP > pool member
what happened is I get this result.
client\source ip > VIP > snat IP > VIP
2nd and 4th are the same IP address, does any encountered the same situation?
What could be causing this issue?
TIA
Hello f5mkuDefault.
What type of VS is the one you are pointing above (https://support.f5.com/csp/article/K55185917)?
Could you check if you have 'translate-address' option disabled in your VS configuration?
Regards,
Dario.
