Leo_377929
Nov 28, 2018Nimbostratus
F5 Power LED Yellow
F5 Power 1 LED turned yellow and Power 2 LED is green. Is the Power 1 module completely down which needed to be replaced or is there any other solution or reason?
can you check the power status one more time & provide the output of following command
tmsh show sys hardware
Please provide output of tmsh show /sys hardware. We faced multiple power supply issues and we ended up replacing them. Power supply is a hot swappable.
Pretty old post, but still for future references & for the OP,
There will be 4 LED indicators in the front panel,
With regards to Power, there are 3 states.
Green solid
- Power supply is present and operating properly. Also indicates when
the system in is power standby mode.
Yellow solid
- Power supply is present, but not operating properly.
Off/none
- No power supply present.After changing the faulty power supply , if alarm exists in LCD (yellow solid) even tmsh shows power status UP.Clear alarm manually from tmsh.
Clearing the LCD and the Alarm LED remotely
https://support.f5.com/csp/article/K11094
