FIPS license and fipsutil info
Hi there.
I'm setting up a new F5 device and need to enable FIPS mode. I've added the FIPS license and validated that the FIPS module is active. However, when trying to configure HSM FIPS running fipsutil info I'm getting the error "No supported FIPS device found". What does this mean? There is not FIPS HSM installed?
I want to validate whether the HSM just needs to be properly set up or if there are any other prerequisites needed to enable FIPS with the current license.
Any tips or steps you can provide to troubleshoot this issue would be greatly appreciated.
Thanks.
The error "No supported FIPS device found" suggests your F5 device can't detect a compatible FIPS HSM. Ensure HSM compatibility, proper installation, activation, and a valid FIPS license.
