Varnisai_91012
Jun 18, 2014Nimbostratus
Solved
FTP issue on LTM
I have a IP, I configured it for multiple ports,like https, https, and ftps(21), the http and https are working fine, when I use ftps , the connection establishes and disconnects immediately, I am using a client s/w to connect to the ftps port, cannot understand the issue , did anyone faced this problem, appreciate your feedback
Can you post your virtual server configuration for the one that isn't working? Just trying to see if maybe you are treating it as HTTP when the underlying communications are FTP.
