Sort By
- Broda_146178NimbostratusAfter another restart, situation is similar.
- What_Lies_Bene1Cirrostratus
A restart being a full box reboot?
Have you tried just restarting the http and tomcat processes?
bigstart restart httpd bigstart restart tomcat
Have you tried increasing the maximum number of concurrent connections?
System > Preferences
I have tried restarting httpd and tomcat. Did not helped. I found some article that it can be memory leaking in this version (11.3.0 HF3).
I thin I will try clean install...
Shame. If you can that would be ideal.
I will let You know about progress.
