arpydays
Aug 06, 2015Nimbostratus
Yeah, the implied directly connected route trumps the static route and as you've found cannot be deleted because of the 'referenced' object protection, in this case a pool in the same network.
There is a way round it though, change the subnet mask on the self-ip to /32 and you should be good to delete it.
cheers
