Help with HTTP Health Monitor
Hello F5 Community!
I'm having a tough time creating an HTTP health monitor to be used on some pool members on my device. I have adapted some of the things that work from existing health monitors in our environment, but after searching in the support community all day I haven't been able to figure this out. I've logged into the F5 and have run the following command:
curl -v --ntlm -u username:password
It runs the script as intended and has the following in the output (which is what I'm trying to capture for the health monitor):
IBM Cognos Software
All this being said... and showing it works using cURL I have created the following HTTP health monitor in the GUI:
Send String:
GET /ibmcognos/cgi-bin/cognosisapi.dll?b_action=xts.run&m=portal/welcome/welcome.xts HTTP/1.1\r\nHost: mynode\r\nConnection: Close\r\n\r\n\r\n
Receive String:
IBM Cognos Software
I'm sure it loos a little frankensteinish as this was pieced together based upon other health monitors that work and what I have seen using cURL. Can anyone advise on why the health check would be failing on these nodes? If you need more information, please let me know.
Thanks for the help!
