Pieter_72260's avatar
Pieter_72260
Feb 07, 2013
High speed logging and round robin load balancing issues
We have a couple of F5 servers that have an iRule that uses HSL to send log messages to a pool of remote rsyslog daemons.
The rsyslog daemons are added to one pool, and the pool is configured to distribute log messages in a round robin way.
All the nodes in the pool are up and running and are in a green state.
I would expect that the log messages get distributed evenly accross all nodes in that logging pool.
However it looks like the round robin balancing is not used.
All the messages sent with HSL are always sent to the same rsyslog daemon.
Only when logrotation kills rsyslog for a short term another rsyslog daemon is selected.
Is there some other stickyness setting that we're forgetting? Or is HSL not supporing the load balancing configuration of the pool?
Or is there another setting that I'm forgetting?
Any ideas?
Thanks,
Pieter
  • udp syslog seems working fine.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.252:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
       when CLIENT_ACCEPTED {
       set hsl [HSL::open -proto UDP -pool loghost]
       set host [HTTP::host]
       set uri [HTTP::uri]
    when HTTP_RESPONSE {
       HSL::send $hsl "<190> [IP::client_addr]:[TCP::client_port] $host $uri\n"
    [root@ve10:Active] config  b pool loghost list
    pool loghost {
       members {
          200.200.200.101:514 {}
          200.200.200.111:514 {}
    [root@ve10:Active] config  tcpdump -nni 0.0 port 514
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on 0.0, link-type EN10MB (Ethernet), capture size 108 bytes
    07:47:58.467764 IP 200.200.200.10.13874 > 200.200.200.101.514: SYSLOG local7.info, length: 42
    07:48:01.220714 IP 200.200.200.10.13875 > 200.200.200.111.514: SYSLOG local7.info, length: 42
    07:48:05.041582 IP 200.200.200.10.13876 > 200.200.200.101.514: SYSLOG local7.info, length: 42
    07:48:06.635777 IP 200.200.200.10.13877 > 200.200.200.111.514: SYSLOG local7.info, length: 42
    this is tcp syslog.
    virtual bar {
       snat automap
       pool foo
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    rule myrule {
       set hsl [HSL::open -proto TCP -pool loghost]
       set uri [HTTP::uri]
    pool loghost {
       members {
    07:50:15.016770 IP 200.200.200.10.13899 > 200.200.200.111.514: S 3784171141:3784171141(0) win 4380
    07:50:15.017474 IP 200.200.200.111.514 > 200.200.200.10.13899: S 1437766692:1437766692(0) ack 3784171142 win 5840
    07:50:15.017487 IP 200.200.200.10.13899 > 200.200.200.111.514: . ack 1 win 4380
    07:50:15.017496 IP 200.200.200.10.13899 > 200.200.200.111.514: P 1:43(42) ack 1 win 4380
    07:50:15.018565 IP 200.200.200.111.514 > 200.200.200.10.13899: . ack 43 win 46
    07:50:16.746792 IP 200.200.200.10.13899 > 200.200.200.111.514: P 43:85(42) ack 1 win 4380
    07:50:16.747472 IP 200.200.200.111.514 > 200.200.200.10.13899: . ack 85 win 46
    07:50:17.442778 IP 200.200.200.10.13899 > 200.200.200.111.514: P 85:127(42) ack 1 win 4380
    07:50:17.443470 IP 200.200.200.111.514 > 200.200.200.10.13899: . ack 127 win 46
    07:50:18.040623 IP 200.200.200.10.13899 > 200.200.200.111.514: P 127:169(42) ack 1 win 4380
    07:50:18.041676 IP 200.200.200.111.514 > 200.200.200.10.13899: . ack 169 win 46
  • Hi nitass,
    I was partially able to get it working using UDP.
    It works fine I just manually launch requests using a browser.
    But the moment we create a higher load (60qps) using multiple threads the load balancing stops.
    Everything is going to one server again.
    And this morning it seems to have worked in one of our DC's with TCP after log rotation kicked in on the rsyslog daemons.
    But the distribution ratio of the requests is not equal. one node gets 25% of requests and the other 75%.
    Kind regards,
    Pieter
  • thanks Pieter. i understand support engineer has found something. would you mind updating us here after he gets back to you?
  • Hey,
    We've got feedback from F5, at first they provided a workaround, which unfortunatly didn't work.
    And after that they mentioned that the thing we're trying to do is not going to work.
    I find it very strange that HSL & F5 doesn't support load balancing of it's own logs.
    We're trying various other possible workarounds but none of them has been working reliably yet.
    Kind regards,
    Pieter
  • what about this one?
    virtual bar {
       snat automap
       pool foo
       ip protocol 6
       rules myrule
       profiles {
          http {}
          tcp {}
    rule myrule {
       when RULE_INIT {
       set static::i 0
       if { $static::i == 0 } {
          set loghost loghostp1
          set static::i 1
          set loghost loghostp2
          set static::i 0
       set hsl [HSL::open -proto TCP -pool $loghost]
       set uri [HTTP::uri]
    [root@ve10:Active] config  b pool loghostp1 list
    pool loghostp1 {
       members 200.200.200.101:514 {}
    [root@ve10:Active] config  b pool loghostp2 list
    pool loghostp2 {
       members 200.200.200.111:514 {}
     send 500 requests to virtual server
    [root@centos251 ~] ab -n 500 http://172.28.19.252/
    This is ApacheBench, Version 2.0.40-dev <$Revision: 1.146 $> apache-2.0
    Copyright 1996 Adam Twiss, Zeus Technology Ltd, http://www.zeustech.net/
    Copyright 2006 The Apache Software Foundation, http://www.apache.org/
    Benchmarking 172.28.19.252 (be patient)
    Completed 100 requests
    Completed 200 requests
    Completed 300 requests
    Completed 400 requests
    Finished 500 requests
    Server Software:        Apache/2.2.3
    Server Hostname:        172.28.19.252
    Server Port:            80
    Document Path:          /
    Document Length:        89 bytes
    Concurrency Level:      1
    Time taken for tests:   2.145340 seconds
    Complete requests:      500
    Failed requests:        0
    Write errors:           0
    Total transferred:      175500 bytes
    HTML transferred:       44500 bytes
    Requests per second:    233.06 [/sec] (mean)
    Time per request:       4.291 [ms] (mean)
    Time per request:       4.291 [ms] (mean, across all concurrent requests)
    Transfer rate:          79.71 [Kbytes/sec] received
    Connection Times (ms)
                  min  mean[+/-sd] median   max
    Connect:        0    0   0.6      0       3
    Processing:     2    3   1.2      3      14
    Waiting:        2    2   1.3      3      13
    Total:          3    3   1.3      3      14
    Percentage of the requests served within a certain time (ms)
      50%      3
      66%      4
      75%      4
      80%      4
      90%      4
      95%      5
      98%      8
      99%     10
     100%     14 (longest request)
     pool stats
    [root@ve10:Active] config  b pool loghostp1|grep -i request
        |     requests (total) = 250
    [root@ve10:Active] config  b pool loghostp2|grep -i request
  • and this is on cmp platform.
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) show sys tmm-info |grep -i sys::tmm
    Sys::TMM: 0.0
    Sys::TMM: 0.1
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar
    ltm virtual bar {
        destination 172.28.20.16:80
        ip-protocol tcp
        mask 255.255.255.255
        pool foo
        profiles {
            http { }
            tcp { }
        rules {
            myrule
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vlans-disabled
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule
    ltm rule myrule {
        when RULE_INIT {
       set static::i 0
          set static::i 1
          set static::i 0
       set uri [HTTP::uri]
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool loghostp1
    ltm pool loghostp1 {
        members {
                address 200.200.200.101
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool loghostp2
    ltm pool loghostp2 {
        members {
                address 200.200.200.111
     pool stats
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) show ltm pool loghostp1|grep -i total\ requests
              Total Requests : 250
    root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) show ltm pool loghostp2|grep -i total\ requests
  • jimmythegeek_10's avatar
    jimmythegeek_10
    Historic F5 Account
    SOL17398 covers this. Load balancing decisions are made in the logging profile, and HSL will stick to the pool member chosen until the server indicates it can't keep up or the connection is lost, at which point another pool member is seleted. As of 12.0 you can change the distribution approach to "balanced" to spread the log messages evenly across pool members. This is done in the unformatted HSL log destination configuration setting for Distribution.
    (old question but answer may help future searchers)
