shoko_388305
Apr 11, 2019Nimbostratus
Solved
How does BIG-IP distribute IP addresses to individual pods?
Hello. I consider to adopt BIG-IP to out project, but I have second thought because I don't know how does BIG-IP distribute IP addresses to pods. When I use BIG-IP for cluster mode on kubernetes, are IP Addresses which are provided by BIG-IP External IP Address, or Internal IP Address? How does BIG-IP know available IP Address range?
Hello Shoko,
Currently, Big-IP does not allocate IP addresses to new pods in a Kubernetes cluster. You need some other system for external IP address assignment, such as MetalLB.
But once you've assigned your external addresses to your services, either manually or using you can load balance to them with your F5.
Best of luck,
Austin
