Sort By
- Kevin_StewartEmployee
I may be interpreting your requirement a little differently, but if you're asking to change a (set)cookie value based on some matching content in the response, here's an option:
when HTTP_RESPONSE { if { [HTTP::header Content-Type] contains "text" } { HTTP::collect [HTTP::header Content-Length] } } when HTTP_RESPONSE_DATA { if { [HTTP::payload] contains "diam" } { if { [HTTP::cookie exists JSESSIONID] } { HTTP::cookie value JSESSIONID "foobar" } } }
This can get tricky based on where you might find this data and how large the response payload is. Collecting all of the response payload can cause a performance hit.
So a few more details of what you're trying to do would help, but you can start here and see where you get to. This is some code that modifies a jsession cookie and persists on it. If you can give some more info, might be able to get a bit closer to what you're trying to do.
when HTTP_REQUEST { Check if cookie has a value if {[HTTP::cookie "JSESSIONID"] ne ""}{ Parse the three ! delineated fields from the cookie if {[scan [HTTP::cookie JSESSIONID] {%[^:]:%[^:]:%[^:]} session holder pri_server_hash] == 3}{ HTTP::cookie value "JSESSIONID" "$session:$holder" Persist off of the primary server token if it is present, not a null value and has a current persistence record if {$pri_server_hash ne ""}{ persist uie $pri_server_hash } } } } when HTTP_RESPONSE { Check if cookie has a value if {[HTTP::cookie "JSESSIONID"] ne ""}{ Parse the second field of the cookie value. The current server always sets its hash as the primary server hash in the second field of the cookie. set jsession [HTTP::cookie "JSESSIONID"] append jsession ":[IP::remote_addr]" HTTP::cookie value "JSESSIONID" $jsession persist add uie [IP::remote_addr] } }
