Sort By
Hi Crown,
You can use "clone" command in iRule.
https://clouddocs.f5.com/api/irules/clone.html
- PeteWhiteEmployee
There are a number of ways - you can use clone pools to just spray it at layer 2, use the iRule clone command as above, use sideband/HSL if you want to change the content or ultimately use MRF to do complex and really groovy things such as having multiple sessions active etc
- AdeolaNimbostratus
Thanks for your response so far.
The problem I am going to have with spraying is, I have the node several hops away from F5. What will be the best way to address that?
- PeteWhiteEmployeeIn which case, an iRule with the clone command would make sense Eg when CLIENT_DATA { clone pool
