IE8_ISSUE
Hi Team,
we are having issue with IE8.namely, when we try to connect to our ibmwebsphere servers over 443 vip all of browsers work properly besides of ie8. And those applications use j session id cookie but ı have selected the cookie default profile from vip resource for that trrafic. initially application is bening opened properly on ie8 browser after that when ı navigate on menus ,i am getting error message like network connection called failed http status 200. Do you think Do i need to write an irule with j session id cookie. i wonder if there is any trick with that. Version 11.2.1 hf3 and vip type is L7 which has both client ssl and server ssl profile. there are http compression, caching,oneconnect, wan and lan optimized profile. also snat aoutomap and xff enabled. also apllication was written via java language.
thank you in advance
