Hamada_Tabosha_
Oct 13, 2014Nimbostratus
images and hot fixes
Dears, Im doing a security assessment for the F5 device, and I found 2 vulnerabilities on my image which is 10.2.4 hf2 as per f5 documents : one of them can be solved by hf3 and the second can be solved by hf4
so if i installed hf3 then installed hf4 over it, will this fix the two vulnerabilities ?
