tomma's avatar
tomma
May 15, 2024
Inquiry on F5's Maintenance Mode Feature for Pool Members
Hello F5 Community,
I'm looking for a way to smoothly transition specific pool members into maintenance mode without disrupting service. Can anyone share insights or best practices on how to implement this in our network infrastructure?
Thanks!
  • Both "disable" and "force offline" actions may answer the requirement as they both provide some level of smoothness
    1. When set to Disabled, a node or pool member continues to process persistent and active connections. It can accept new connections only if the connections belong to an existing persistence session.
    2. When set to Forced Offline, a node or pool member allows existing connections to time out, but no new connections are allowed
    So, for the first you need to disable the node then wait for a sufficient time to make sure there is no active nor persistent connection related to that node. Typically, you will disable a node 30 minutes to a few hours before the maintenance schedule.
    For the second, you set the node to forced offline and wait a few minutes until there is no active connection to this node. Note that persistence here is immediately lost and any client who is in the persistence table but who is not actively connected will load blance to the next member.
  • What are you trying to archive? I dont understand your posts at all so please tell what you trying to do...
    • tomma's avatar
      tomma
      I'm trying to find a way to move current established connections from one pool member to another, so I can perform maintenance on the first pool member.
      • Than please explain whats wrong with disabling a pool member? You can either disable it (no new connections - established one will timeout/expire but persistent will be allowed furthermore) or you force offline so all connections to this poolmember will be timeout/expire
        EDIT: Sorry I made a mistake - ForceOffline a BIGIP will close all connections immediately - On Poolmember this does not work
    • tomma's avatar
      tomma
      So you're telling me that there is no other way than just to "force offline" a pool member and wait till all the old connections are no longer active? I was hoping there could be a way to move active connections to another pool member...
      • Can you clarify your requirements? what do you mean by smoothly transitioning into maintenance mode, and what do you want to exactly achieve? If you don't want to affect end user experience, then depending on your application logic you may have to use either disable member or force offline, the first is less aggressive cause it will also wait for persistent sessions to expire, if persistence is not an issue for you then I don't see why "force offline" would be a problem
  • tomma's avatar
    tomma
    Additionally, it's worth noting that our service infrastructure may not be fully compatible with the "forced offline" feature. Hence, we are particularly interested in alternative solutions or configurations that align better with our requirements.
    Any insights, best practices, or real-world experiences from the community regarding implementing maintenance mode in F5 deployments would be highly appreciated.
  • tomma's avatar
    tomma
    In our network infrastructure, we frequently encounter scenarios where we need to perform maintenance tasks on specific pool members while ensuring uninterrupted service for end-users. Thus, we are keen to explore if F5 offers any dedicated features or mechanisms to gracefully transition a pool member into maintenance mode.
