frankcheong_304
Jan 26, 2012Intermittent Connection Problem Between Active/Stanby LTM 1600 and a pair of Cisco 2960
I have a pair of LTM 1600 (namely LTM-A & LTM-B) running in active/standby mode and a two pair of Cisco2960 (namely WAN-2960-A, WAN-2960-B, LAN-2960-A & LAN-2960-B). My setup is as below:-
Network Interconnection:-
LTM-A Interface 1.1 -> WAN-2960-A Port 1
LTM-B Interface 1.1 -> WAN-2960-B Port 1
LTM-A Interface 2.1 (Fibre) -> LTM-B Interface 2.2 (Fibre)
LTM-A Interface 2.2 (Fibre) -> LTM-B Interface 2.2 (Fibre)
LTM-A Interface 1.3 (internal-trunk) -> LAN-2960-A Port 1 (ether-channel Port-channel 3)
LTM-A Interface 1.4 (internal-trunk) -> LAN-2960-A Port 2 (ether-channel Port-channel 3)
LTM-B Interface 1.3 (internal-trunk) -> LAN-2960-B Port 1 (ether-channel Port-channel 3)
LTM-B Interface 1.4 (internal-trunk) -> LAN-2960-B Port 2 (ether-channel Port-channel 3)
LAN-2960-A Port 3 (ether-channel Port-channel 5) -> LAN-2960-B Port 3 (ether-channel Port-channel 5)
LAN-2960-A Port 4 (ether-channel Port-channel 5) -> LAN-2960-B Port 4 (ether-channel Port-channel 5)
LTM-A & LTM-B:-
Trunk List: trunk interface 2.1 & 2.2 named as Fibre, trunk interface 1.3 & 1.4 named as internal-trunk
Trunk Setting: LACP: Enable, LACP Mode: Active, LACP Timeout: Long, Link Selection Policy: (Auto), Frame Distribution Hash: (Source/Destination IP Address)
VLAN List:
Internal, Tag: 4093, Untagged Interface: internal-trunk, MTU:1500, Fail-safe: Enable, Fail-safe-timeout: 15, Action: Failover
External, Tag: 10, Untagged Interface: 1.1, MTU: 1500, Fail-safe: Enable, Fail-safe-timeout:15, Action: Failover
pri-failover, Tag: 4092, Untagged Interface: Fibre, Fail-safe: Disable
All interface running at 1G full-duplex
part of show run for LAN-2960-A & LAN-2960-B:-
LAN-2960-Ashow run
vtp domain f5-private
vtp mode transparent
spanning-tree mode pvst
spanning-tree extend system-id
port-channel load-balance src-dst-ip
vlan 4093
name f5-private-vlan
interface Port-channel3
switchport trunk native vlan 4093
switchport mode trunk
no keepalive
flowcontrol receive desired
interface Port-channel5
switchport access vlan 4093
switchport mode access
interface GigabitEthernet1/0/1
spanning-tree portfast disable
channel-group 3 mode active
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
channel-group 5 mode desirable non-silent
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5 - 1/0/24
interface Vlan4093
ip address 192.168.96.1 255.255.255.0
LAN-2960-Ashow vlan
VLAN Name Status Ports
1 default active Gi1/0/25, Gi1/0/26, Gi1/0/27
Gi1/0/28
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
4093 f5-private-vlan active Gi1/0/5, Gi1/0/6, Gi1/0/7
Gi1/0/8, Gi1/0/9, Gi1/0/10
Gi1/0/11, Gi1/0/12, Gi1/0/13
Gi1/0/14, Gi1/0/15, Gi1/0/16
Gi1/0/17, Gi1/0/18, Gi1/0/19
Gi1/0/20, Gi1/0/21, Gi1/0/22
Gi1/0/23, Gi1/0/24, Po5
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
4093 enet 104093 1500 - - - - - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
LAn-2960-Ashow vtp status
VTP Version capable : 1 to 3
VTP version running : 1
VTP Domain Name : f5-private
VTP Pruning Mode : Disabled
VTP Traps Generation : Disabled
Configuration last modified by 0.0.0.0 at 3-8-93 22:38:54
Feature VLAN:
VTP Operating Mode : Transparent
Maximum VLANs supported locally : 255
Number of existing VLANs : 5
Configuration Revision : 0
All server have dual interface connecting to LAN-2960-A and LAN-2960-B using interface bonding mode 6 miimon=100. Found that there are consistent packet drop for both LTB as below:-
Interface Statistics Bits Packets Multicast Errors Drops
Name Status In Out In Out In Out In Out In Out Collisions
mgmt DOWN 0 0 0 0 0 0 0 0 0 0 0
1.1 UP 358.4G 4.5T 291.9M 446.2M 8.2M 5.9K 0 0 59.0K 444 0
1.2 DOWN 0 0 0 0 0 0 0 0 0 0 0
1.3 UP 2.2T 196.1G 241.1M 153.9M 880.0K 26.6K 0 0 309.9K 1.5K 0
1.4 UP 2.4T 277.5G 249.8M 164.9M 111.5K 16.7K 0 0 58.6K 821 0
2.1 UP 19.0M 19.0M 20.4K 20.4K 17.7K 17.8K 0 0 0 0 0
2.2 UP 11.6G 11.9G 11.6M 11.7M 16.7K 16.7K 0 0 0 0 0
ON LAN-2960-A there are 408 packet drop on interface 1 and 175 packet drop on interface 2 (connecting LTM) while all other interface record 0 packet drop. I would like to know what seems to be the problem? I have also tried to swapping another UTP cable while still encounter intermittent connection drop. Am my configuration correct?
