Sort By
- Justin_106597Nimbostratus
the logs on the f5 for the client trying to ssh is Rule /Common/Infoblox_Management : IP address: x.x.x.x
client gets connection reset.
i changed that to remote port. I now see in the logs why it is rejecting the other client Tue Jan 20 09:24:56 CST 2015infoF5TESTtmm[12495] Rule /Common/Infoblox_Management : IP address: x.x.x.x Tue Jan 20 09:24:56 CST 2015infoF5TESTtmm[12495] Rule /Common/Infoblox_Management : Source Port: 50454 Tue Jan 20 09:24:56 CST 2015infoF5TESTtmm[12495] Rule /Common/Infoblox_Management : IP and Port checks failed. DROPPING connection
is it looking at the source port and not destination port?
- Michael_JenkinsCirrostratusYou can check out the TCP wiki page for TCP to see what the different options are (https://clouddocs.f5.com/api/irules/TCP.html).
I got it to work. I will move into prod soon and verify it works. thanks for all your help.
- Michael_JenkinsCirrostratusGood deal. Don't forget to mark one of the answers as the solution if it seems like the best solution.
