Eric_Hartwell_1
Apr 15, 2014irule to check node connection
I want to make an irule which checks to see which node a server is connecting to. the following irule doesnt seem to write to /var/log/ltm.
log_node_connection
when CLIENT_ACCEPTED { log local0.info "--- Node IP address: [IP::server_addr]" } when HTTP_REQUEST { log local0.info "Client IP address: [HTTP::host] " }
How can I change this irule to accomplish the task?
thanks,
Eric
We use this which gives a complete picture of the connection from client to server:
when SERVER_CONNECTED { This logs information about the TCP connections on *both* sides of the proxy set client_remote "[IP::client_addr]:[TCP::client_port]" set client_local "[IP::local_addr clientside]:[TCP::local_port clientside]" set server_local "[IP::local_addr]:[TCP::local_port]" set server_remote "[IP::server_addr]:[TCP::server_port]" log local0. "Got connection: Client($client_remote)<->($client_local)LTM($server_local)<->($server_remote)Server" }
