metagraphica_25's avatar
metagraphica_25
Apr 11, 2017
Solved
iRule to redirect http and https to https over port 8888
I'm Definitely new to writing iRules. Trying to build one iRule to apply to 2 VIPs. One VIP listens on port 80 the other on port 443. The iRule would redirect any normal HTTP or HTTPS traffic to HTTPS on port 8888. Below is what I have right now, but it doesn't seem to work. Any help or advice would be greatly appreciated. Thanks.
when HTTP_REQUEST { if { [HTTP::uri] equals "; or [HTTP::uri] equals ";} { HTTP::redirect "; } }
  • Updated code with corrections...
        if { [HTTP::host] equals "zzzzzz.xyz.com" or [HTTP::host] equals "zzzzzz.xyz.com"} {
            HTTP::redirect "https://zzzzzz.xyz.com:8888"
    What you want is..
       switch [HTTP::host] {
          "xxxxxx.xyz.com" -
          "yyyyyy.xyz.com" -
          "zzzzzz.xyz.com" { HTTP::redirect https://[HTTP::host]:8888[HTTP::uri] }
    The "-" means use the action of the following condition. So all of the hosts listed will redirect to same hostname on port 8888.
  • Try applying this
        HTTP::redirect "https://[getfield [HTTP::host] ":" 1]:8888[HTTP::uri]"
  • Do you have SSL Client and HTTP profiles applied to your TCP/443 VIP? I know the HTTP Profile is required to read the HTTP traffic, but I'm pretty sure you'll need to decrypt it as well to be able to fire the HTTP_REQUEST Event. -Cory
    What you want is..
          "xxxxxx.xyz.com" -
          "yyyyyy.xyz.com" -
  • Cory O, yep I noticed that for some reason the https VIP didn't have the correct SSL client profile applied. Fixed than and now everything is working. Thanks.
