Sort By
- Nathan_F__F5_Employee
Hi axeli,
I believe it depends on the software version you are running. I just looked through my various lab devices on v12.1 through v15.1 and noted the following:
- v12.1.x does not appear to have a template for OWA 2013.
- v13.1.x does not have a template labeled with "2013" specifically but it does have one named "OWA Exchange" that I believe is based on OWA 2013.
- v14 .1.x appears to be the same as v13.1.x.
- v15.1.x has an "OWA Exchange 2013" template (which I believe is the "OWA Exchange" template from v13 and v14) as well as an "OWA Exchange 2016" template.
With that in mind, as long as you are on v13.1.x or later then I believe you can use the "OWA Exchange" template or the "OWA Exchange 2013" template (if you are on v15.1).
-Nathan F
