dragonflymr
Mar 31, 2017iStats v13 command help
Here is help displayed by cli istats command:
Usage: istats [-s ] []
is one of: 'set' 'incr' 'get' 'remove' 'dump' 'drop_row'
'drop_column' 'clear_row'
is a single quoted argument: "keyspace ... "
(like "ltm.pool /Common/mypool counter mystat")
is one of: 'counter' 'gauge' 'string' 'text' 'signed' 'unsigned' 'bin'
'dec' 'hex' 'timestamp' 'timeval' 'uinthex'
must be specified for 'set' and 'incr', and must be an integer for 'incr'
The for a gauge may be negative. Use 2 dashes before the
negative value (like 'incr "... gauge ..." -- -1')
I wonder if there are is any info how to use operations like drop_row, drop_colum, clear_row
What is [-s ]
description "keyspace ... " - what is keyspace and column? If possible some example of key using all above elements and multiple columnsIs there any description what can be stored in types: 'text' 'signed' 'unsigned' 'bin' 'dec' 'hex' 'timestamp' 'timeval' 'uinthex'And how those behave in relation to value used. What is difference between timestamp and timeval. I had ipression that those can be set without using value (like automatically place current time at the moment key is created in value) but it seems not be the case.Piotr
