dyobbs_25515
Jun 19, 2012Link Load balancing across 6 x ISP links
hi,
here's the scenario:
1. Cloud provider is offering web/data services via hosting
2. They have their own BGP AS number and public IP addresses to manage
3. They are peered to 3 different ISPs, each has its own redundancy that makes it 6 links
However, when using multihoming on BGP, you cannot achieve load balancing of links on this.
Can F5- Link controller do the following:
1. Load balanced 6 links
2. Can F5 participate in the BGP peering?
3. Will F5 connect directly to the ISP links or after the provider's peering router?
4. What could be proposed setup to achieve such?
Any info is appreciated. thanks!
