Roberto_GB_2613's avatar
Roberto_GB_2613
May 10, 2017
list data-group using tmsh script
Hi all, I'm developing some scripts in order to make easier certain operation with data-groups. I figured out how to add, modify and delete elements this way but when it comes to show the data-group... No way. I duplicated the same command but with different syntax to see if something worked:
cli script VPN_users_SHOW {
proc script::run {} {
    set cmd "tmsh::list /ltm data-group internal auth_users_access"
    tmsh::log "Executing the command: $cmd"
    eval $cmd
    list ltm data-group internal auth_users_access
To run the script I simply execute it: "run cli script VPN_tmp_user_access_SHOW"
I expected to list the data-group but it does not show any data. Any suggestion of what is missing?
  • Hello,
    This is a tcl, so, to print you can do this way:
        set li [tmsh::list ltm data-group internal auth_users_access]
        puts $li
    Regards
