Kevin_Masui_185
Jul 02, 2015Nimbostratus
Load Balancing for VMware View 6.0
Hello,
We are deploying VMware View 6.0 with multiple Connection Servers. Currently there is only one network for Connection servers and we were planning on configuring one-armed load balancing. Is this method acceptable for View or should we be using a routed architecture? If I understand correctly, with SNAT you will not be able to determine the client's source IP. This may pose an auditing issue from the security team but I'm not sure. Are there any best practices for the architecture and configuration of the F5 with View?
We plan to use the iApp to help with the configuration.
Thanks in advance
