Mr_Ruppel_26924
Jun 07, 2016Nimbostratus
load usc config file does not work
Hello ,
I want to replace a old F5 BIG-IP 3600 software 10.2 with a F5 BIG-IP 5050s software 12.1
I have made a archive file from the old one and I tried to load this file with tmsh.
load sys ucs ******.ucs no-license no-platform-check
I get the error " Jun 7 12:39:00 emerg load_config_files: "/usr/libexec/bigpipe load" - failed. -- BIGpipe eom operation error: 01070307:3: Invalid interface 1.5 Jun 7 12:39:03 emerg load_config_files: "/usr/libexec/bigpipe base daol" - failed. -- BIGpipe eom operation error: 01070307:3: Invalid interface 1.5 Configuration loading error: base-config-load-failedERROR: UCS installation failed."
This is the only error.
The new BIG-IP 5050 has no Interface 1.5 -1.8
The old one has this interfaces but this interfaces are disable. How can I erase the interfaces from the ucs config to load the archive to the new one? Or how can I disable the Interface check in tmsh load command to load this archive?
