Justine_313324
Sep 11, 2017Altostratus
LTM and GTM on the same box on both site then use GTM sync
Hi everyone! I would like to ask if using a single box on both GTM and LTM. My design is I have two F5 appliances with 2 modules(GTM and LTM) that will be located on each DMZ site(2 DMZ sites). I would like to use GTM for global load balancing and LTM for the local load balancing of the app/web servers. Since I have two appliances, I would like to GTM sync the two appliances.
Question: Is this possible?
Thanks!
