Fabio_Sozzi_308
Nov 30, 2010Manipulates SSL payload for 2 Packets inside same session
i've a problem with a creation of an iRule.
I have a session TCP and i need to manipulate the first two packets of the session. The packets NOT contain a Layer 7(HTTP,DNS,Ecc..) payload but only simple binary payload(a sequence of ASCII code).
My problem is that after the first packet, which can be manipulated with event CLIENT_ACCEPTED and CLIENT_DATA (and the method TCP::collect), i can't find a event that allows me to modify the next TCP payload packet.
if you can help I have set the HTTP profile. So the only events Layer 7 can be used are those HTTP.
There is an event that satisfies my request?
Thanks in advance for any response.
Kind Regards,
Fabio.
