MS
May 28, 2014Nimbostratus
MDM and Edge client for Android
Hi There,
Just stumbled upon a problem with the Edge client for mobile platform. Since i plan to use certificate based auth and deliver the certificates to end devices via MDM. The Edge client on IOS is able to fetch the certificate and all works fine.
However for the Android platform i cannot get the certificate on the edge client that was installed via the MDM. The only possible way is via remote url. Any hints ?
