Gill_32697
Oct 23, 2012Nimbostratus
Solved
Need redirect irule help please !
I need a redirest irule, I can not use http class.
The developer only want the irule to act on the specifc uri path and send to pool1, any other uri path or no uri path at all goes to pool2.
http://test-swbc.com/akcelerant/
http://test-swbc.com/idsakcelerant/
http://test-swbc.com/idsakcelerantmtg/
http://test-swbc.com/lmakcelerant/
Vip: 10.200.1.62
Pool1 node: 10.16.5.50
Pool2 node: 10.25.25.100
Im lookiing for the I irule to use the if and else statements so that I can add more uri's as needed.
I'm not good a scripting so i realy need a completed irule that I can just paste with little editing. I can adjust the
nodes and uri's but the structure needs to be there compete. I not good at adding the brackets and quotes.
Thank you.
Correct, add another line after the first one. THe new line would look like
