jaikumar_f5
MVP
I suspect you maybe on Guest, can you confirm that by running this below command,
tmsh show sys hardware | grep -A1 Platform
If it says Guest, you may not able to see power/fan status. Only if its a hardware, you would see.
Also if it was a hardware, I'm positive you should have atleast seen Down or something else. But since you get blank, I'm suspecting it could be a guest machine.
Canan
Dec 26, 2020Nimbostratus
Thank you for your attention but it is hardware appliance.
- jaikumar_f5Dec 28, 2020MVP
Can you open a support case and keep us posted too.
