I guess you are missing a after pool keyword, use the command like this
check if small a or capital A after pool keyowrd will work.
tmsh
list gtm pool a all load-balancing-mode
tmsh show gtm wideip a all detail | grep 'WideIp\|Destination'
The following command will find pools with a return to DNS option and print the name of the pools.
tmsh -c 'cd /; list gtm pool recursive all-properties one-line' | awk '/return-to-dns/{print $4}'
My Other GTM master Commands which i use frequently and keep customizing them based on the requirement and then pul them in excel sheet and then use DATA TAB, and there is one option text to columns
And use Delimited radio button and run the Wizard to convert F5 Command output text command output to mulitple colums for easy readability.
My Other GTM master Commands you can try to get more results of your choice
bash mode
netstat -na |grep 4353
tmsh list /gtm server all
tmsh list gtm wideip a one-line tmsh list gtm wideip aaaa one-line tmsh show gtm wideip a detail tmsh show gtm wideip a pools show gtm wideip a all
tmsh show gtm listener tmsh show gtm listener all-properties
tmsh show gtm pool a detail tmsh show gtm pool a detail field-fmt show gtm pool a members detail show gtm pool a members fireld-fmt show gtm pool a members field-fmt server
show gtm server all detail show gtm server detail virtual-servers show gtm server detail virtual-servers field-fmt list gtm server addresses virtual-servers
show gtm server detail show gtm server detail all
list net self all-properties list gtm listener all-properties list gtm listener vlans
show sys ip-address all-properties
tmsh show gtm wideip A all detail | grep 'WideIp\|Destination'
tmsh show gtm all detail | grep -e -i Gtm::Server -e "Server"
show gtm wideip a all detail | grep -e -i -n NAME_OF_YOUR_GTM_SERVE
show gtm wideip a all detail | grep -i -e Gtm::Pool::A grep -i -e 'Pool\|Destination'
show gtm wideip a all detail | grep -i -e Gtm::Pool::A grep 'Pool\|Destination'
show gtm wideip a all detail | grep -i -e Gtm::Pool::A | grep -i -e 'Pool\|Destination' grep -i -e 'Pool\|Destination'
show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e Gtm::Pool::A grep -i -e 'Pool\|Destination'
only one pipe
show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e NAME_OF_YOUR_GTM_SERVER
show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e 'NAME_OF_YOUR_GTM_SERVER$'
show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' | grep -i -e '^NAME_OF_YOUR_GTM_SERVER$' = No results
show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e '\^NAME_OF_YOUR_GTM_SERVER$'
show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e 'wideip\|Destination' grep -i -e '\^NAME_OF_YOUR_GTM_SERVER$'
show gtm wideip a all detail | grep -i -e '^gtm' grep -i -e '^NAME_OF_YOUR_GTM_SERVER$'
show gtm wideip a all detail | grep -i -e '^NAME_OF_YOUR_GTM_SERVER$'
show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -i -e '\NAME_OF_YOUR_GTM_SERVER'
show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -e -i Gtm::Server -e "Server" grep -i -e '\NAME_OF_YOUR_GTM_SERVER'
show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -e -i Gtm::Server -e "Server" grep -i -e '$NAME_OF_YOUR_GTM_SERVER'
show gtm wideip a all detail | grep -i -e 'wideip\|Destination' grep -i -e 'Pool\|Destination' grep -e -i Gtm::Server -e "Server" grep -i -e '$*NAME_OF_YOUR_GTM_SERVER' -C 2
show gtm wideip a all detail | grep -i -e '$*NAME_OF_YOUR_GTM_SERVER' -C 1
show gtm wideip a all detail | grep -i -e '$*15*' -C 1
show gtm wideip a all detail | grep -i -e '$*gtm*' -C 3 grep -i -e '$*NAME_OF_YOUR_GTM_SERVER'
show gtm wideip a all detail | grep -i -e '$*gtm*' grep -e -i NAME_OF_YOUR_GTM_SERVER
