There is a rule where Probe Timeout should be 3xProbe Interval + 1
Probe Interval is the Interval between two health check
Probe Timeout is the time if no response received the member or node will be marked down
Hope it helps
Yann
- Ayush_Gupta_332Nimbostratus
Lets say a health monitor is configured as below:
Interval : 10 seconds Timeout : 31 seconds Probe Interval: 1 second Probe Timeout: 5 seconds
Could you explain how these 4 things are related or how each parameter plays its role to determine the health of the end server? Considering both scenarios where the end server passes the health check and fails.
Thanks again.
- Yann_Desmarest_Nacreous
Hope it helps
Yann
Thanks again.
