Muhammad_Irfan1
Oct 01, 2014Cirrus
Redundant power supply logs
I disconnected the redundant power supply of F5 LTM 11.4.1 and then connected it back. Now I am receiving logs continuously, although I have removed the warning from the F5 LTM by checking the warning.
- Local0.Emerg 10.50.171.3 Oct 1 14:48:01 www emerg system_check[7952]: 010d0006:0: Chassis power supply 2 has experienced an issue. Status is as follows: FAN=good; STATUS=bad.
- Local0.Emerg 10.50.171.3 Oct 1 14:48:01 www emerg system_check[7952]: 010d0017:0: Power supply 2 meas. standby vo: milli-voltage (0) is too low.
- Local0.Emerg 10.50.171.3 Oct 1 14:48:01 www emerg system_check[7952]: 010d0010:0: Power supply 2 fan-1: fan speed (0) is too low.
- Local0.Emerg 10.50.171.3 Oct 1 14:48:01 www emerg system_check[7952]: 010d0017:0: Power supply 2 meas. AC input v: milli-voltage (0) is too low.
- Local0.Emerg 10.50.171.3 Oct 1 14:48:01 www emerg system_check[7952]: 010d0017:0: Power supply 2 meas. main outpu: milli-voltage (0) is too low.
How to remove this problem
