iRule
Mar 08, 2023Cirrus
replace part of URI for specific URL and pass remaining
Dear Community,
I need to replace only specific part of URI i.e "/abc/defg/" with "/uvw/xyz/" in a URL. All other URLs should not be altered.
"/abc/defg/" will appear in the begning of URI
For example:
From: https://bbcc.com/abc/defg/v1/derh/user-cases/ profile/morning
To: https://bbcc.com/uvw/xyz/v1/derh/user-cases/ profile/morning
All Other URLs should not be alerted and sent to pool without modification in URI.
Regards
iRule It should be the following and any other additions can be added in a similar manner. You might consider speaking with the application team and have them perform the corrections on the server as this should only be done as a last resort in an iRule.
when CLIENT_ACCEPTED priority 500 { set DEFAULT_POOL [LB::server pool] } when HTTP_REQUEST priority 500 { if {[string tolower [HTTP::uri]] starts_with "/abc/defg/"} { HTTP::uri [string map {"/abc/defg/" "/uvw/xyz/"}[HTTP::uri]] pool pool_web } elseif {[string tolower [HTTP::uri]] starts_with "/123/456/"} { HTTP::uri [string map {"/123/456/" "/78/910/"}[HTTP::uri]] pool pool_web } elseif{[string tolower [HTTP::uri]] starts_with "/asdf-asdf/"} { HTTP::uri [string map {"/asdf-asdf/" "/lkjh-lkjh/"}[HTTP::uri]] pool pool_web } else { pool ${DEFAULT_POOL} } }
