Kai_M__48813's avatar
Feb 21, 2017
Solved
sha1 or sha256 default when creating csr
im going to use the webui to generate a san csr, but there is no indication on whether sha1 or sha256 will be used. the version im generating on is 12.1.1. is there a quick way to verify this, either in webui or through cli?
  • SHA-256 should be selected in the later versions such as yours. This will be represented by 2048 bits in the key section (near bottom when generating CSR.) After that your PKI authority should handle the rest.
    • Nicholas_P__308's avatar
      Nicholas_P__308
      Icon for Cirrus rankCirrus
      Kai, thank you the the string to confirm! Always best to verify as much as possible!
    • Kai_M__48813's avatar
      Kai_M__48813
      thanks!
      i was also able to veriy this by running openssl req -noout - text in /config/test.csr | grep -i signature
