Sort By
- liycheng_55020Nimbostratusand where can I get a checklist about methods on or not on different versions?
- L4L7_53191NimbostratusI believe the method should be get_product_information()
- Matt is correct, for v9 and above there was a change in the API and it seems (from your use of the ITCM* namespaces) that you are still using the v4.x APIs. If you go into the iControl API reference
http://devcentral.f5.com/Wiki/default.aspx/iControl/APIReference.html
- liycheng_55020NimbostratusThanks for all your help.
- liycheng_55020Nimbostratusand I am sorry to update you guys again:
- Change the "ITCMSystem" to "System". ITCM was for 4.x.
