infra_netteam_O's avatar
infra_netteam_O
Aug 13, 2014
Static route gateway X.X.X.X is not directly connected via an interface
Hello,
When verifying bigip.conf file, an error is reported about a network route. But the error has no reason to be there. Here is the error:
load sys conf file /config/bigip.conf verify Validating system configuration...
. . Validating configuration... /config/bigip.conf 01070330:3: Static route gateway 10.10.99.254 is not directly connected via an interface. Unexpected Error: Validating configuration process failed.
When I then exit tmsh and look at my network configuration I see that 10.10.99.254 is on the same network as one of my interfaces.
netstat -rn
Kernel IP routing table Destination Gateway Genmask Flags MSS Window irtt Iface 192.168.1.0 0.0.0.0 255.255.255.252 U 0 0 0 HA
127.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 tmm0
127.3.0.0 0.0.0.0 255.255.255.0 U 0 0 0 mgmt_bp
192.168.20.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan20
192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
10.220.220.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan220
10.194.94.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan194
127.2.0.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0.1
10.10.96.0 0.0.0.0 255.255.252.0 U 0 0 0 vlan1 &&&& LOOK HERE &&&&
0.0.0.0 10.10.99.254 0.0.0.0 UG 0 0 0 vlan1
This configuration is up and running. I can even ping 10.10.99.254... I am just worried this error hides something more serious. fyi we run version BIG-IP 11.3.0 Build 3144.51 Engineering Hotfix HF8
thanking you in advance
Alberto
  • We had similar issue and upon having a close look realised that the GW IP address was not in the range of the interface. The interface was configured /29 instead of /28. Corrected the mask and it worked.
    • pradeep-LL_3065's avatar
      pradeep-LL_3065
      Step-1: Delete default gateway under Network Routes. Step-2: login into LTM VM under config edit into bigip_base.conf
      modify your interface ip save & Quit
      run tmsh load sys config
      login to GUI crate a default route by adding gateway.
  • Hello Hoolio,
    Thank your for your reply. This "fore reload" did not help though. I still have that message, when verifying the config file.
    Thank you
    best regards
    • boneyard's avatar
      boneyard
      Icon for MVP rankMVP
      might be wise to open a support ticket with F5 support if you can.
  • Hi Alberto,
    Can you try removing the binary database and rebooting to force a reload of the configuration?
    sol13030: Forcing the mcpd process to reload the BIG-IP configuration http://support.f5.com/kb/en-us/solutions/public/13000/000/sol13030.html
    Aaron
  • What interface is 10.10.94.254 connected to? Based on your 'LOOK HETE' It appears you believe it to be connected to vlan1, but that is 10.10.96.0/22 which would not include 10.10.94.254
    • mimlo_61970's avatar
      mimlo_61970
      Ignore me, it is 10.10.99.254, I misread somehow. Yes, that is part of 10.10.96.0/22 so I have no explanation
